I don't know whats wrong... The system idles at 120F/49C but when a game is played (CounterStrike) the system kicks up to 190F/88C. This measurement is taken with Via Hardware Monitor. The thermometer HAS to be broken. One thing that may have lead to this is I had to bend the thermo down a little bit before putting the CPU in the socket. It wouldn't drop down because the thermo was so high. I bent it at an angle so that it would fit in.
Even if it is broken, why is there such a huge difference between idling and after 100% cpu usage? In counterstrike, artifacts will start showing up and then a few minutes later the entire system crashes. It is a new Chrome Orb cooling a Tbird 800@800. Its not an overclocked system at all. Could it be possible I used too much Thermal compound? Its the white silicon based stuff. I also know that the Chrome Orb cracked a corner of the Tbird core, but the system runs stable if not doing CPU intensive stuff.
Or is it the video card? Because of the artifacts showing up that may be a possibility. The video card is a 3d Prophet SDR with stock cooling. Any suggestions or insight would be greatly appreciated. Thanks!
