I'm running an Athlon XP 1600+ on my KR7A mobo. When i boot up, it posts 1050 mhz. I've seen this problem posted everywhere, but mine seems to be a little different then everyone elses. I can power one fine at first and can go into bios and change to 1600+(133). I can exit and save. Sometimes the system will shutdown as soon as I exit the bios but most of the time it will reboot at 1600+ fine. When it shuts down just after the save and exit, i can try to power up and it will for like 2 secs and then back off again. This is one part. The other problem is when I manually power off after adjusting this setting in the bios and reboot. Windows will open and everything work fine. It will power back up fine just after I power down but if i wait about 10 minutes or more, the computer will do nothing. No lights, fans, nothing come on. I can reset cmos and it takes be right back to the beginning with the 1050 mhz post. Can someone please help???
Abit KR7A-Raid w/bios @ 6G
Antec 1030 w/350 ps
Athlon 1600+
256mb crucial pc2100 ddr
PNY GForce 2 Pro/Gts 64mb ddr
Soundblaster Live Xgamer
Sony 175E Cdrw
Maxtor 40g ata133 7200rpm (not running raid)
3 Antec 80mm case fans (2 rear, 1 front) all running off ps, not mobo
1 enermax 80mm case fan (front running off mobo)
sk6 heatsink w/mechatronic 80mm fan Ultra High Speed(running off ps, not mobo)
2 additional USB ports (included with mobo)
Antec 1030 w/350 ps
Athlon 1600+
Sony 175E Cdrw
