ABIT KG7-RAID Problem
boypung
12
I got a problem w/ my Raid Mobo.
It seems when I try to use RAID-0 The BIOS could not detect any hard drives in my computer.
Primary Master : No Drive
Primary Slave : No Drive
Secondary Master : No Drive
Secondary Slave : No Drive
I already set the First Boot Device, Second Boot Device, Third Boot Device to ATA 100
And it works just fie with my Win 2K.
Anybody can help me with this problem ?
Thank You
boypung
12
Oh and also I'm using AMD Athlon 1.4GHz 266FSB
but in the BIOS setting it shows
CPU Operating Speed : 500(100)
Multiplier Factor : x5
CPU FSB Clock : 100 MHz
This doesn't quite the same with my hardware, how should I change this setting?
Insane3D
19,446
First, do you have your hard drives connected to the RAID controller ports? They are the orange ones labeled IDE 3 and IDE 4. As far as the bios, you should set the multiplier to 10.5 and the CPU FSB clock to 133. :)
