Hi i was wondering if the abit IS7-E had any temperature reading problems?
because mine is reading 45C idle and 69C under Full Load... i just dont see why this is possible im running my thermaltake volcano 7+ at full spead (6000RPM) and its just the same.. that is at default vcore and not overclocked..
Plus CPU-Z says my vcore is 1.46 volts is this true? the bios states 1.525 volts and if i overclock the cpu running at 1.7 volts the temps are the same except under full load it may reach 72C... i would return this motherboard but its been over 3 months since i baught it, and i didnt check the temp / voltage readings when i first used it..
i have checked for air bubbles or any trapped dust and everything... its all okay.. and temps are still the same
