hmmm, i'm under the assumption that a 3pin connector on the mobo is considered non-variable as i dont' think you can control the voltage coming out of them correct? Fan speed monitoring is not the same as fan speed control i'm assuming. And the power supply has a dial to control the speed of the two led fans that are in it, but that doesn't affect the mobo voltage in any way, nor does the dial control the voltage output of any of the connectors coming out of the power supply so far as i've been able to tell, they're all hooked up and nothing changes when i change the dial (other then the 2 power supply fans).
other other thing, somebody on ABIT mentioned that the main limitation of the motherboard 3 pin connectors is that the total power (watts) comign out of the connector is limited to 6W, so if i double them up i would have to use 2 fans that dont' take more then .25A each (W=V*A)....that sounds about the normal for each fan, but i'll double check when i get home tonight...
"1. Connect to a non-variable power connector only. For best performance, Antec recommends that LED fans only be connected to a standard (steady-voltage) 12V DC power connector. If your motherboard or power supply supports fan speed control, DO NOT connect the LED fan to that variable-voltage header or output."[/quote]
