Pro has better heat solution for MOSFET and North/South bridges. Supposedly also better quality components, but the fundamental manufacturing would be same. If you only want to overclock, nonPro or even E model should be enough.
The std IP35 is probably the better vfm (& the-E even more if you don't need RAID & firewire).
Ultimately the Pro is the better mobo but the % price increase from the std will be higher than the % performance increase.
