imported_mystik
I'm looking for a replacement for my old abit IP35 Pro motherboard. This morning I was playing TF2 and my screen filled with artifacts and my computer froze. I restarted, played for about another 20 minutes, it did the same thing. I swapped the graphics card out thinking it was a graphics card problem, but when my computer booted up my network adapter and my PCI slots (x-fi sound card, tried in multiple PCI slots) weren't working. I swapped video cards back again yet it still wasn't working. After messing with drivers for a bit I still couldn't get it going so I formatted and reinstalled Windows but still had the same problem.
I was also concerned that my graphics card (a 9800GTX) might be bad because I got artifacts the first time I tried to install Windows and had to switch to an older card (a 6800GS). I also get artifacts and lock ups on the Windows desktop after a fresh install, but only with the 9800GTX. Should I RMA the card (they won't accept it if it isn't really defective) or wait, get a new motherboard and see if I still have the problem? I also can't try my 9800GTX in my older system because it is too long to fit inside the case.
Anyways I was looking at these two motherboards for possible replacements:
Asus P5Q Pro Turbo P45 - http://www.newegg.com/Product/Produc...82E16813131377
Gigabyte GA-EP45-UD3L P45 - http://www.amazon.com/Gigabyte-Core-...7488517&sr=8-2
Should I get one of these or possibly something else?
One more thing, I just replaced my 520w power supply (which I had to RMA) with a 450w which is the minimum required for a 9800GTX. My computer ran fine with it for three and a half weeks. I finally got my replacement, a 700w PSU. Should I swap them out and see if the broken network adapter, broken pci slots, and artifacts stop? I don't think insufficient power could cause those problems or am I wrong?
