Overkiller
The backplate provided w/ the SLK-947U cannot be attached using the stock setup of the Abit IC7 Max3. My question is:
Do i remove the retention cage & apply the backplate (if so how would i go about removing the retention cage)
And if not then should i just use the retention mechanism?
