Abit BX6 rev.2 & PIII 700 problem
sam509
70
I have just upgraded my Abit BX6 rev.2 (has latest bios) to a PIII 700 mhz Coppermine in a FC-PGA to slot 1 adaptor (adaptor labeled PC133 slot 1 bridge). I have a dual boot system with Win 98SE and Win 2000., 128mb pc 100 ram, Elsa GeoForce DDR. I have the CPU setup for 700(100) (default) and core voltage to 1.65v (default). When I boot to Win 98 and after the Windows color screen shows up I get the blue screen error message.
A fatal exception OE has occured at 0028:D4772E1B in VXD EMU10K1(01) + 00009C5B. The current application will be terminated.
I get this message a couple of time as windows loads the startup applications. Then if I run IE5, Explorer, or any of several other apps. I get the same message and it kicks me back to the desktop. After 2 or 3 error messages the machine locks up.
Funny thing is Win 2000 seems fine no chrashes runs IE5 fine. CPU tempature never gets above 35 C.
My old CPU was a Celeron 466 in a slot 1 adaptor and was rock solid.
Anyone have any Idea what is wrong, do I have a bad CPU? Memory problem? Video Card problem?
Thanks in advance,
Mike
Sinsemilla
8
Go and download the latest drivers for your Sound Blaster Live. That will probably fix your problem.
