Not many folks had any luck OC'ing the 466, but I've got an idea.
I've got a 366 Celeron I bought from a member here. Guaranteed to hit 550 with the Golden Orb that came with. It is presently on my Wife's computer renning at 366. Since it is a LX mb, it won't let it do the 550 dance.
I would be willing to swap you even up. You could then run your processor at 100mhz FSB and still remain at 66mhz for the system. I'm sure it would be much more stable this way.
I would E-Mail you or Private Message if you had them enabled...
