Hi guys...
I have an old Abit BH6 with a slotket + FC-PGA Celeron 566MHz clocked to 850MHz. I was using a generic slotket until today when I bought an Abit Slotket III thinking my old slotket was the one causing all my instability and finicky slot connection.
Basically, there's apparently a problem with the connection between my BH6 Slot 1 and the slotket. Only very rarely do I get it to work correctly, and there seems to be some sort of magic angle that must be held before it will even boot up - else the system will power up but nothing will ever show on the monitor. I've done all the usual troubleshooting, but I'm 99% sure it boils down to the connection. I thought it was the slotket since it was a generic brandless OEM one so after trying to get it to work for the whole of yesterday(I installed a new Enermax 431W PSU and while doing so shifted the position of the slotket ever so slightly causing it not to boot up again), I went and bought a brand new Abit Slotkey III, thinking it'll solve all my problems. Well, turns out it didn't, same thing still happens, and I'm getting no video at all even though everything else powers up.
So my question is why would this happen? Does anyone have a similar problem? I'm guessing I'm an isolated case, but I thought it's worth a shot posting.
Here's a list of other things I've done to determine that the cause was not anything else, but the connection:
Tried CPU on another old Socket 370 motherboard - CPU works
Tried CPU+Slotket on another old Slot 1 motherboard - doesn't work
Changed graphics card from 3dfx Voodoo3 to Matrox G400 - doesn't work
Seated/unseated graphics card/memory - doesn't work
Minimized system components to only CPU, 1 DIMM and graphics card(everything else unplugged) - doesn't work
Cleaned up the entire case by blowing and using a paintbrush - doesn't work(looks a lot cleaner/neater though)
Disconnected/reconnected HSF - doesn't work
Discharged CMOS - doesn't work
Cleaned Slotket connector base with 70% isopropyl alcohol medical wipes - doesn't work
Seated/unseated Slotket numerous times, tried numerous angles and numerous insertion depths - out of the entire afternoon I only got it to work like 2-3X, and any slight movement after that caused it not to work again.
Unplugged/plugged ATX power connector - doesn't work
Tried new Abit Slotket III - doesn't work
As you can see above, I've tried basically everything known to any person with some PC knowledge, and everything else common sense, but nothing worked
I'm at my wits end now...probably have to bring it to a qualified computer repair technician to see what's wrong with the mobo, unless any of you have any other ideas apart from what I've already done?
