Question AASRock B550 Phantom Gaming 4 System Panel connections
Jeff H
1,611
4
Guys,
I'm in the final stages of setting up an ASRock B550 Phantom Gaming 4 system. I've attached two photos that center on some confusion I'm having. One photo is a shot of the corner of the board, where the System Panel Header (item #19, p. 1 in the manual) resides, the other is a close up, better showing the connections. Here's where my confusion sets in.
The case is a Fractal Design Focus G. The wires in the bundle include: Power switch (two wires), Reset switch (two wires), PLED +/- wires, HDD +/- wires. I've placed those wires on the B550 System Panel Header. Next to the System Panel Header is a Power LED & Speaker header (item #20 on p.1 of the manual. Why are there what appear to be redundant headers on the motherboard (PLED +/-)? Additionally, there appears to be an extra PLED+ header on item #20. And, no speaker wire in sight.
Am I missing something, or should all the wires from the case reside on the System Panel Header? Do case speakers still exist, or do they reside on the motherboard?
TIA,
B550 Phantom Gaming 4 System Connector.jpgB550 System Panel Connector Closeup.jpg
Jeff
Feb 4, 2009
35,862
17,402
I’m no expert so if someone gives different advice follow their advice.
Looks like some sort of legacy speak header. I wouldn’t bother with it.
Iron Woode
31,266
12,783
Guys,
TIA,
View attachment 39849View attachment 39850
Jeff
The answer is simple and goes back a few years.
Some cases have a 3 pin power led connector. The speaker one is obvious.
