- Jun 1, 2002
- 4,543
- 0
- 0
Okay.. waiting for final approval from you guys.. also couple of concerns for you guys to answer in the end
Cases PC - ATX - Modified (window, rare color..)
CHIEFTEC Server Chasis (Aluminum Workstation Tower with Plastic Front Cover) Black w/acrylic window 400W AMD approved Power Supply, Powered by Foxconn (Deer) Front Accessible: 4 x 5.25", 2 x 3.5", Internal: 4 x 3.5". Compare to Antec SX1040 and Save Weights
$99.99
RAM
Mushkin 256 DDR PC2100 (owned, upgrade to 768 later)
CD Recorder/Rewritable Drive - Black
Lite On 32x12x40 CDRW Model LTR-32123S BLACK Color Full OEM with all accessories.
$59.00
Floppy Drives - Black
SAMSUNG 1.44MB BLACK FLOPPY DRIVE Model# SFD321B/KEB - OEM, DRIVE ONLY 1 Year Warranty
$13.00
Mouse
Logitech Optical Mouse
$25
Hard Drives - IDE
MAXTOR Quiet Drive 40GB 7200RPM Model # 6L040L2 -D740X OEM, DRIVE ONLY
Specifications:
Size: 40 Gigabytes
Interface: IDE ULTRA ATA133/100
Seek time: 8ms
RPM:7200
Cache 2MB
OEM(Drive alone) 3 Year Manufacturer Warranty QUIET DRIVE - "L" denotes Fluid Dynamic Bearing Motors--* Works With PC & Mac *--
$79.00
Keyboards - English - Black
BLACK ORtek MCK-800 Multimedia Keyboard. PS2. Built-in 16 Multimedia hot keys (6 Programmable keys). One-touch solution to popular internet web sites, Multimedia, and favorite application. Comfortable silent & tactile switch. Agency Approvals: FCC, CE, BSMI, WHQL, CSA. OS Compatibility: Windows 95/98/2000/Me/NT 4.0 (Support NT with PS/2 keyboard Only)
$12.00
Monitors - Black
NEC model AS70-BK AccuSync 17" CRT RETAIL The AccuSync 70 17-inch (16.0-inch viewable image size) monitor delivers the quality and reliability traditionally seen only in pricier models
Specifications:
Screen 17" (16" viewable image size)
CRT 0.27 mm dot pitch
Maximum Resolution 1280 x 1024 @ 66 Hz
Horizontal Frequency 31 kHz to 70 kHz
Dot Pitch: 0.27 mm trio
Recommended Resolution: 1024 x 768 @ 85 Hz Max 1280 x 1024 55,66 Hz
Dimensions: 15.9 in. (W) x 16.5 in. (H) x 16.5 in. (D)
Signal Cable: Captive 15-pin mini D-SUB connector
General Manufacturer Limited Warranty: 3 Years CRT, Parts and Labor
$145.00
Motherboards - AMD
Special Reduced PriceSOLTEK SL-75DRV4 (Purple Ray Ver.) VIA KT266A AMD Althon & Duron DDR **ATA133** 200/266 MHz FSB Socket A ATX MOTHERBOARD - RETAIL VIA VT8366A + VT8233A chipset. FSB 266/200 MHz. Supports DDR SDRAM @ 266/200 MHz. Supports Ultra ATA 133/100/66. Multiplier Setting. BIOS FSB Setting. AGP, DIMM Voltage Setting. RedStorm Overclocking. SmartDoc. Anti-Burning Shield. SCR (Smart Card Reader) Interface. Optimized for all Socket-A processors.
**2-YEAR WARRANTY**
Award from: VIA Hardware, www.clubedohare.com.br, Highly Recomended www.amd3d.com...(click Detail Specs for detail).
$71.99
Sound Card
CREATIVE LABS SOUND BLASTER LIVE! 5.1 - OEM Features: EMU10K1, Digital Signal processor EAX, advanced audio effects, Speaker mode / Creative Multi-Speaker Surround (CMSS) mode , and Dolby Digital 5.1 support
$32.00
Video Card
MS-8853 -- MSI GeForce3 Ti-500 64MB DDR 4x AGP Video Card with TV
$107.00
CPU Fan
Glacier Cooler (already owned)
Speakers
Logitech's THX certified Z560 4.1 surround sound system
$136
Subtotal » $646.99
Shipping and Handling Charge »$93.00
Grand Total » $ 845.99
Now couple of questions:
1. What's your comment on the monitor? I just added it because price was right + 85hz @ 1024x768 is fine with me
2. How about the motherboard? I was gonna go with Soyo but what's the pros/cons on this mobo?
3. Am I forgetting anything???
$99.99
RAM
$59.00
$13.00
Mouse
$25
Hard Drives - IDE
Specifications:
Size: 40 Gigabytes
Seek time: 8ms
RPM:7200
Cache 2MB
$79.00
$12.00
Monitors - Black
Specifications:
$145.00
Motherboards - AMD
**2-YEAR WARRANTY**
$71.99
Sound Card
$32.00
Video Card
$107.00
CPU Fan
Speakers
$136
Subtotal » $646.99
