AA+HDR Not working in oblivion on 8800GTS?
Jules
Cant seem to get it to work. i tryed forceing it thought the control panel but nothing. any ideas?
AmdInside
1,355
Are you using Windows Vista? I don't think it works under Windows Vista but I could be wrong.
gramboh
2,207
I just put together a new system on Friday. Oblivion runs fine with AA+HDR. I am forcing AA/AF from control panel and telling the game to use HDR.
Edit- This is in Win XP32 SP2 with the last official drivers (97.92 I think).
Jules
Im doing the same but it doesnt look like AA is even working.
TheRyuu
5,479
14
Get nhancer and make sure that the HDR+AA compatibility bit is enabled.
It "should" work.
Try these drivers.
Those are the XTreme-G 100.95 drivers which seem to work very well on 8800 cards. And I think you'd be able to tell if HDR+AA was enabled or not. Just look at the roof of a building or the edge of your sword. Jaggies there or not?
And take a screenshot if your not sure and post it here.
Make sure that when you install the driver you do it THE RIGHT WAY <-IMPORTANT
(most of the time a driver doesn't work right it is because you installed it the wrong way...)
Driver Cleaner Pro is no longer free but you can still find the free 1.5 version on the internet and that will do just fine (google "Driver Cleaner Pro").
AmdInside
1,355
Not sure if its required but do you by chance have the latest patch installed for Oblivion? I run Oblivion at 2560x1600 so AA is not needed for me :D
AmdInside
1,355
It does look like AA is enabled. Just look at the girls arms. You can definately tell on her arms.
Mogget
60
Can someone confirm that AA+HDR with an 8800 definitely does work in Oblivion (with the appropriate drivers)?
It's just that I know many people who think it doesn't.
TheRyuu
5,479
14
Yea it does.
If you have the appropriate drivers (97.92+), install them correctly, and make sure the HDR+AA compatibility bit is enabled.
Jules
Yea it does.
Im it seems i got it to work but I think i did it wrong. im forcing AA though Nhancer and turning on HDR in oblivion is that the right way?
TheRyuu
5,479
14
Yea it does.
Yea thats the right way and I think the only way to get it to work.
Mogget
60
Yea it does.
I'm slightly confused ? Do you mean both the "XTreme-G 100.95 drivers" and the 97.92+?
And is the procedure the same for XP and Vista?
TheRyuu
5,479
14
Yea it does.
By 97.92+ I mean the 97.92 driver and above. (I should clarify this one, the 97.92 driver and every driver that has been released since the 97.92 driver...and are for the G80)
And how can you install 2 different drivers :p :D
So no, not both. For 8800 users I think that the 100.95 driver is a good choice now because it does bring bug fixes and slightly improved performance over the 97.92 (the only other 8800 driver out there thats half way decent).
So for 8800 users, try this driver.
(you can also look in the downloads section for 32/64 bit of both XP and Vista XG drivers).
You can use stock or XG version it shouldn't make a different. Just make sure you have the 97.92 driver or greater, have AA enabled in the driver, HDR enabled in the game and with nHancer make sure that the HDR+AA compatibility bit is enabled.
Any questions? :D
(don't you find all these drivers confusing??? I do :confused: <-Me, but I try to at least sort out the mess...)
Jules
Yea it does.
Any questions? :D
um i dont see that HDR+AA Compatibility bit enabled for some reason.
TheRyuu
5,479
14
Then enable it :p
Just got to the Oblivion Profile in nhancer (if it's not there then make one, and make sure it's pointing to the Oblivion exe).
And in the compatibility thing make sure the HDR+AA compatibility bit is enabled.
I made a picture for ya:
Picture (click me)
k??? :p
Any other questions???? :D
Pugnate
690
AA doesn't work in Oblivion.
If your frame rate remains the same then trust your eyes because the jaggies haven't gone.
gramboh
2,207
If I have time before I go out of town after work tomorrow I'll post two pics to prove AA+HDR works on an 8800 w/ 97.92 drivers in Oblivion 1.2 tomorrow.
Jules
Then enable it :p
Picture (click me)
k??? :p
Using your setting the AA Stopped working. not sure whats going on. But if i use global it works.
Jules
Well i check it again and for some reason if HDR+AA is enabled and i check 4x aa it wont work. but as soon as i turn it on and put AA on it works fine, whats the deal?
TheRyuu
5,479
14
What ever works for ya :p
SPARTAN VI
803
I have prior 97.92 and HDR + AA didn't work. I'll be updating tonight.
Doesn't work in Vista.
SPARTAN VI
803
It works (97.92). In fact, it's almost free. Without AA, running through the IC Market District (with crowded cities 30 on) I averaged about 36fps (FRAPs benchmark). Ran it again with 16xSSAA and averaged 30fps. Practically free. :D
1680x1050 HDR 0xAA 16xAF
Min: 6
Max: 116
Average: 37.82
1680x1050 HDR 16xSSAA 16xAF
Min: 12
Max: 64
Average: 30.747
