AA and AF settings
Xgamer11
37
I was wondering what settings for anti-aliasing and antisotropic filter do u guys use?
i mostly play css
BFG10K
22,709
3,003
16xAF for all games, max out the resolution and then go as high as you can with AA.
Munky
9,372
Seeing how you use a 9800p, I used to have one too, and I played CS:S at 1024x768, 8x AF, 2xAA. Usually in single player games I'd use 4xAA, but for online play you need higher fps.
VIAN
6,575
I don't play that, but I would use 4x/8x. I don't often go farther than that because you get diminishing returns after that, but if I can, I will. Unless you have a CRT, resolution bumps would probably be better before you go to higher settings. Since the textures in CS aren't that sharp, I would lower the AF from 8x to 4x if there was I needed performance. Then AA to 2x from 4x if I needed more performance.
