- Jun 11, 2003
- 301
- 0
- 0
OK, I finally decided to get with the program and start setting these things (anti-aliasing, anisotropic filtering). Check sig for specs on the Dragonslayer system. Right now I'm using the 3.9 catalyst drivers, but will be switching to the 4.7s soon. I haven't bought Doom3 yet and probably won't for a couple of months. The main games I'm concerned about are UT2004, UT2003, UT, Unreal2, UnrealXMP, Quake]|[ Arena and Postal2 as those are pretty much the only ones I have installed right now; of course, Doom3 in a couple of months.
I noticed Rage3DTweak in ControlPanel/Display/Settings/Advanced area and here are my AA/AF settings right now (I did change some other settings to Quality as opposed to performance):
DIRECT3D
- # of samples (FSAA) >> 2
- Anisotropic Filtering >> By Application
- Anisotropic Mode >> Quality
- FSAA Mode >> Quality: App. Pref.
OPENGL
- # of samples (FSAA) >> Disabled
Also, are there any other settings I need to worry about that need to be changed from the default values? I'm new to messing with AA and AF and would like to set them to 2X AA and 4X AF for a while and see how they work, then maybe 2X/8X and maybe 4X/8X. I do know that there might be some problems forcing AF in some games though. Any help would be appreciated. Thank you.
DIRECT3D
OPENGL
