Hello - my rig is as follows:-
- A8V Dlx Rev 2.0
- Brand new BIOS battery installed as a matter of course when doing the build
- Fully clean Slipstreamed WinXp SP2 install
- Via 4.55 Hyperion Loaded
- 2 x 512 DDR 500 Kingmax @ 2.8v
- 3200+ 939 @ 10 x 260 @ 2.6gig @ 1.575Vcore in BIOS - @ Load, Vcore never drops below 1.505v
- HTT @ 800mhz
- Memory @ 5:3 / 216.67mhz
- All other BIOS settings are a default / auto
- Zalman 7000 AlCu with AS3
- NB sink removed and cleaned and AS3 applied
- nVidia 64 meg AGP Video Card - Basic
- 1 x 80gig WD HDD 8mb cache
- 1 x DVD 16x ROM
- 1 x 52x CD Burner
- PS2 Optical Mouse
- PS2 K/B
- 1 x PCI Audio Card - Basic
- Various items running off USB 1.0 & 2.0 ports
- 2 x 120mm Fans
- Topower 420w Dual Fan "Gold" P/Supply
- 12v reading @ Load = 11.48v
- 5v @ Load = 4.999v
- 3.3v @ Load = 3.344v
- Running BIOS 1008
** THE GOOD NEWS **
- Rig is fully P95 stable over 24 hours
- Rig is fully CPU Burn stable for 24 hours
- Memory is fully stable @ Memtest 1.40 for 24 hours
- Temps are fine - never gets over 58'C, and when it does - which is usually after 3 - 4 hours, it stays there
** THE BAD NEWS **
- Every 3rd or 4th cold-boot up, it wont boot-up, and I have to press re-set and re-enter the BIOS settings etc.. because it says "Overclock Failed" ....
- Every now and then, when doing **non-load** stuff like email or word documents, it freezes / locks up on me - no mouse movement - no hdd - no keyboard etc .... I have to do a re-set to get it back and then re-enter the BIOS details
I have tried the BETA BIOS's up to and including 1009.005 - no difference.
I am at my wits end !!
I have built *many* systems before and NEVER had this sort of a problem.
Any suggestions would be ENORMOUSLY & very graciously appreciated.
Alex [Tillo] Itoni
- A8V Dlx Rev 2.0
- HTT @ 800mhz
- 1 x DVD 16x ROM
- 1 x 52x CD Burner
- PS2 Optical Mouse
- PS2 K/B
- 2 x 120mm Fans
- Running BIOS 1008
** THE GOOD NEWS **
** THE BAD NEWS **
Alex [Tillo] Itoni
