I've had this board for over a year now and when I built the system I was not able to figure out where to install the wires for my front USB port. I now need access to that front port. My computer box front USB port has 2 connectors. 1 is a 3 wire connector, red wire (VCC), white wire (U-) and green wire (U+) and 2nd connector is 1 wire black (GND).
On page 2-28 of the manual, it shows how to install the supplied USB Header for 2 additional USB ports (USB56 or USB78). Do I install the front USB connectrs to the USB 2.0 Header pins (USB56 or USB78) at the bottom of the motherboard? It appears that each set (USB56) & (USB78) is for 2 USB ports with 5 prongs on the top & 4 prongs at the bottom. If this is the correct area to use, does it matter which one I use USB56 or USB78 and whether I use the top or bottom prongs.
Now that I typed this out, I guess I've answered my questions as it seems the bottom of the USB56 is for the 5th USB port - Voltage, -,+ and GND.
I would appreciate it if someone would confirm this.
Thanks in advance!
Thanks in advance!
