Originally posted by: Aries64
Originally posted by: Operandi
Yes that's very helpful, thanks. :thumbsup:
I'm working on a "recommended motherboard)
thread in the SPCR forums so I'll be sure to use this information. I'm glad to hear the board can control the chassis fan as well as the CPU fan header. The detailed settings for various temp thresholds looks great too.
A few questions; what is the difference between "CPUFan Start Temperature" and "CPUFan Start PWM", it sounds like they do the same thing? Have you tried SpeedFan on the board?, it could be a temporary solution to the new BIOS issue.
From what I can tell, the "CPUFan Start Temperature" and "CPUFan Start PWM" are not the same thing. The "CPUFan Start Temperature" is the temp at which the CPU Fan turns on (begins to spin). The default is 5C, so on an air-cooled system it starts as soon as you power the system on. I'm not really sure what the "CPUFan Start PWM" does, but I believe it is tied-in to the way Q-Fan operates in conjuction with Cool N' Quiet.
Unfortunately, I never tested this theory, but BIOS 0311 worked great for me, as I was able to run Cool N' Quiet without issue, but usually I just ran the system at full speed. I had been running an XP-90/92mm Panaflo L1BX combo. The L1BX ran between 1300-1554 RPM between idle and full load.
Then I switched over to an SI-120/120mm Panaflo L1BX while still running BIOS 0311. Strangely, the 120mm Panaflo L1BX still spun at about 1,300 RPM at idle (I would have thought that the size advantage the 120mm has over the 92mm would have allowed the 120 a greater RPM delta over the 92mm fan). I really wish BIOS 0404's Q-Fan worked properly for me, as my 120mm L1BX seems to cool nearly the same at about 1,400 RPM compared to full-speed, which is approximately 1,785 RPM. Why have the fan spin at full speed when it doesn't need to, you know?
I tried SpeedFan, but I couldn't get the (CPU) fan to speed up at Temp2 and Temp3 - the CPU fan stayed at the low fan speed setting I have assigned it, letting my CPU heat up more. I didn't like that, so I have decided to wait for another BIOS revision, and hopefully that will solve my Q-Fan issues.
So, for a re-cap, after my update to BIOS 0404, now:
(a) Q-Fan does not work
(b) Cool N' Quiet does not work
(c) I cannot change the default values from what they are in Q-Fan.
(d) BIOS 0404 is pissing me off because of items a-c
