JPB
Ok, so I try to run Asus Update. It wont even install. It says no Asus motherboard available. And when the update program does install, it wont work. How to I get this thing updated? thanks
Edit...It says this also...Please install Network Card and TCP/IP network driver first, otherwise ASUS Update can not work properly.
However, I do have a working cable connection.
