a8n32-sli deluxe cold boot problem
pRS317
26
one day, out of the blue, i started having a cold boot issue. basically, when turning it on, the hd's spin up but it doesn't beep, produce an image on the monitor, or send power to the mouse or keyboard. i then have to turn off via the psu, let everything spin down and then it'll fire up. it seems almost like a capacitor problem?
any thoughts on this would be appreciated!
pRS317
26
i have the coolermaster realpower 550. it has a power meter that never gets anywhere near the rated wattage...although who knows how accurate that is. the only other psu i have is a 500 watt phantom, which should be able to fire the system, but really isn't intended for oc'ed/gaming comps.
i've also been having problems with the overclock settings. sometimes i'll fire up a game and notice a slowdown. when i check the clock speed, it's set to default. a simple reboot without changing any bios settings reactivates the overclock.
i don't have any problems with instability. if it were the psu, i was thinking it would show during heavy usage...although maybe there's a cap in it that is failing?
SerpentRoyal
Banned
May 20, 2007
3,517
Reflash to the latest BIOS. If you still have problem with the Phantom, then RMA the board after you've tested RAMs using Memtest86.
pRS317
26
i finally realized it was the ram voltage as you suggested, serpent. i must have put it too far down when i went to my summer clock, which, now that i think about it, was when the problems first started....doh! thanks for pointing me in the right direction :D
