a8n32 mb temperature problem
vxmqzz
70
the pc probe says mb temp is 47c which should be below 45c
while my cpu is around 43c
is there anyway I can reduce the mb temp?
I know there is an official a8n32 thread, but now it gets so long that I can not find the info I want :(
Any a8n32 users here? Please give me some advice about this board, thanks :p
n7
21,281
4
With really hot weather like we've been getting here lately, mobo temps report over 50C usually.
I got over 60C during some UT2k4 the other day.
lopri
13,329
709
You can try installing a fan blowing on the NB from the case. But mine also runs average 10C higher than the CPU. (Right now, CPU 35C and the board 45C) I wouldn't worry too much unless it causes actual instability.
vxmqzz
70
My case is p180, which has one rear fan and one top panel fan, both blow air out, CPU heat sink is Scyth Ninja plus , the fan on it can only do blow in, so the hot air from the cpu is passing from the mb heatsink
is there any better way to arrange these fans ?
