Hi all,
I got a A8N -SLi Deluxe, and installed all the software. The nv Firewall wasnt working properly, so i uninstalled it, but can't find it now so cant re-install it. (ie, cant find NV Firewall, any where on the CD)
(Ive looked at the other A8N-Sli posts but they dont help me)
Can someone tell me exactally i need to re-install to get the nv Firewall back?
2nd prob.
I dont know how to set up my RAID.
Using the onboard RAID, and my single SATA 80gig Seagate Disk. (Do i use the Black or Red RAID ports?)
When i boot, ther is an option to config the RAID, but its empty so i got no idea's...
Im using XP (not the 64-bit one) and the RAID controller isnt configed. I also cant make sense of the RAID guide on the Manual or CD.
Thanks For any help!
(p.s. I havent messed with bios)
specs:
A8N-Sli Deluxe
AMD Athlon 64 3000+ (1.8ghz)
2x 256mb Samsung
ASUS AX 300 extreme 128mb - 128bit
20gig Seagate IDE (back up disk)
DVR-108 Pioneer DVD RW +/-
2nd prob.
specs:
A8N-Sli Deluxe
2x 256mb Samsung
