A8N + Antec True Power 550W
Promethply
1,741
The Antec Truepower 550 comes with a 20 - pin ATX plug, but it should work just fine with the A8N's 24 - pin connector.
GuitarDaddy
11,465
I've been using the 20pin Antec 550 with this board for over 3 months and it works great, you just leave the 4pins nearest the chipset fan open on the mobo connector. Antec also makes a 24pin model it is the 550 EPS, with this one I think you have to split the 6pin AUX connector into 4pin and 2pin because the mobo has a 4pin AUX.
bbarlow10
11
I got the ANtec Truepower 550 EPS12V -- it's like a server version. It's has the 24 pin mobo connector, and 2 SATA. It also has a 8 pin 12 V (second rail) connector that I use to power my 6800...though I did have to make a 8 pin to 6 pin pci-x connector myself.
