slashandburn
I'm new about these parts, hopefully getting straight to the point isn't considered bad etiquette.
I got this A88XM-PLUS with a Kaveri A10 7700k. GPU is a Sapphire R9 280x (HD7950?) and the ram is 2x 4gb Corsair Vengeance DDR3 1866Mhz (9,10,9,27) 1.5v. In dual channel.
My problems I think stem from the board. Specifically a bad bios flash. It came with BIOS version 1501. Newest was 2302. Flashed 2302, everything seemed fine until i was poking about in cpuz checking my ram timings were correct, as the bios DOCP profile seemed to read it right in the bios but miss completely by the time windows booted. So my manually configured ram timings were good. But then the NB frequency in the cpuz memory tab caught my eye. 200Mhz. Which seemed bizarre. I'm no expert but I expected nearer 2000Mhz. Back to BIOS. NB Freq and CPU / NB V offset definately set to auto. Reboot. Check cpuz again. 200mhz. All other settings at default. No ovérclock. Baffled.
Then ensued a bunch of stability issues that let me to eventually reflash the old 1501 bios. Now cpu-z shows a far more friendly NB Freq of ~1600mhz, occasionally dropping to 1400. I think its at least stable now.
Does this sound right? The Northbridge frequency? I'm suddenly very suspicious as to why it would default to 200mhz, and whether or not its current "auto detected" frequencies are correct. I don't think they are. Temperatures all seem fine under load.
Any insight would be greatly appreciated. I'm reluctant to manually push the NB frequency without really knowing what ballpark I should be going for.
Cheers
Iain
Cheers
Iain
