Hello,
I have an A7v333 with a relatively recent BIOS. I was formerly running an XP 1800+. I received an XP 2400+ (retail) and upon installing it, the computer does not boot. The power led on the motherboard is lit. When I turn on the power, everything "seems" to turn on, but nothing happens. I've taken the board out of the case and placed it into cardboard with just the video card and ram. Still no luck.
Figuring maybe the processor was dead, I then went back to the old processor. No luck.
Since I didn't have the manual, the only thing I haven't done is "short" the RTC Ram jumper by touching it with a screwdriver while the battery for the CMOS was out. I did remove the battery, though.
My first attempt when I go back home will be to try that. I'm wondering, though, if anyone has other suggestions. Neither of my computers at home will work so I guess I'd like to have all the options laid out before me in case that doesn't work. The processor was pretty cheap. My local computer companies charge about $75/hr for labor. Which would make it absurd to take it in, since I could probably buy a new motherboard / processor for that price. No local stores will let me return a motherboard without a restocking fee. Basically all my hopes for not getting bent over on this upgrade hinge on the RTC Ram reset.
But, is it really possible that I blew two processors in this ordeal? I am a little bit concerned about the thermal compound on the fans. One is a bit loose and the other a bit sparse. However, the MOBO quickly powers off if it senses the CPU will overheat. Which is a good sign, because that means SOMETHING is working, but a bad sign, because not everything is.
Enough rambling. Any advice?
A7V333 newish BIOS (3 months or so old)
XP1800 / XP2400
512mb Crucial DDR 2700 and/or 256mb Mushkin Green
ATI 9700pro
XP1800 / XP2400
ATI 9700pro
