A7V266 - Voltage Regulator Output Setting?
sanna
OK, this is probably the same on all motherboards, but I don't know what it is. The manual states:
This jumpters allow you to manually adjust the CPU core voltage. It is recommended to use CPU Default as the CPU core voltage. CPU Default means the Vcore is generated according to the CPU VID configuration. For each jumper setting, there are two voltage options, depending on the CPU used.
I have an athlong 1.4G onboard, so how do I find out the voltage I should use for the CPU?
Thanks all in advance....
