- Jul 20, 2001
- 2
- 0
- 0
I have an Asus A7V133 motherboard with an AMD TBIRD 1.4 GHz processor, 300W power supply, and 512MB PC133 RAM.
I pressed the power switch on the case after I had assembled the system and nothing happened. The PLED on the motherboard came on when I turned the power supply on, but the system does not power on when I press the power button on the case. I verified that I had all the leads inserted correctly into the system panel. I even removed all the leads but the Power Switch lead but the system will not power on. I tried reversing the Power Switch Lead but nothing happens when I press the power switch on the case. None of the fans begin running and I get no beep codes. The system acts dead. I would believe that the motherboard has a short but the PLED lights up and, unless I am mistaken, that means the motherboard is getting power from the power supply.
Any ideas?
Any ideas?
