A7V133 Problems! NEone help?
Warthog912
1,653
Check this out fellas- I have a Asus A7V133 in a generice box w/an XP 1500+ and a generic cooler. I've had this system running stable @1.4Ghz for months now. The case has in it some intake/exhaust fans and cools well. The case also contains a cut-off 6ft light (worm) that I use to light up the case. Last night, I left the light on all night by accident, when I woke up this morning, the power light on the case was on, but no fans or nething else was going. So I cut the power, and tryed to restart the machine. NOTHING. It's odd tho, my ps is still good, and I've switched the ram, and the proc out so it's not those. I think I may have burnet up the mobo, but when I turn the power switch on on the psu, the green AGP light on the mobo comes on. Has anyone had any expierience with this. What do ya guys think?
Any help is appreciated!!!
Thanks
Warthog912
Utterman
2,147
That has never happened on my A7V133 (most stable board ever!). Try to reset the bios by shorting the pins and see if that helps.
