- Oct 27, 2000
- 9,968
- 592
- 136
I wanted to put out a warning, there is a problem with the latest BIOS 1002A for the A7V133. This new BIOS enables some memory feature that Mosel/Mushkin do NOT like, you will find random amounts of memory will showup at POST... usually 128MB will show as 64MB sometimes even 32MB. So far the only known memory to have this problem is Mosel Rev2 or Mushkin Rev2.
To fix the problem just revert back to BIOS 1001D instead. Unfortunely right now we can't get the extra memory performance 1002A offers if you own this memory.
The new A7V 1006 BIOS also seems to enable these memory features that cause this problem... I have confirmed the problem with the A7V133 1002A BIOS, I will do some more testing with the A7V 1006 BIOS to be double sure.
Also this problem only happens with Cas2 settings, with Cas3 it is fine.
