A7V & Hard Drive Light Mystery.
Jonny
1,574
Okay guys, I doubt any of you have seen this before. My new A7V is running perfectly, except my hard drive light does not work. And yep, I have changed the cable to see if I had it in wrong, but it does not work.
Is this just a small defect on my motherboard? Also, I tested the LED to make sure it was good by putting it in the power light, and it worked.
Nothing I can do to fix this right?
Thanks.
hungrypete
3,001
the A7Vs HDD light only works for the ATA100 controller. Sorry man, light no workie on ATA66 controller
Jonny
1,574
Thanks hungrypete, thats awesome. Iam getting my IBM deskstar GXP 45 GB today or tommarow, so then my hard drive light will work! Right?
hungrypete
3,001
should work just fine.... but alot of people have had problems getting the ATA100 controller to work. I guess it is just hard to get working, after you get it working it should be fine though. Good Luck, those 75GXPs are pretty fast!
Whitedog
3,656
ummm, mine works on the 66 controller..
the trick was, when I plugged it in like I "thought" it was supposed to be, it didn't work. I flipped it around and wallah!
try flipping it around. I think they have the pins marked wrong on the board?
icculus
60
Thats strange.. it wouldn't work no matter how I plugged it in. I just moved my drives over to the ata100 controller anyway (even though they are a 33 and a 66). The controller works with widnows fine as long as you properly install the windows drivers and flip the proper bios settings if you want to boot from it.
MisterM
According to my Manual Revision 1.01 the IDE Activity LED`s will only work@the ATA100 controller:
<< [IDE Activity LED (Hardware Setup)
(Some useless stuff)
Read and write activity by devices connected to the Primary or Secondary IDE connectors will not cause the LED to light up.
BUT there are 3 revisions of the A7V out AFAIK (this is from my memory and may be inaccurate):
1.01: Original one with onboard sound and without the multiplier adjustment
1.02: Without the sound, but with the multiplier adjusting dip switches
1.03: As 1.02 but with an thermal probe preinstalled somehow to measure CPU temperature
Maybe the HDD activit LED does work on one of those revisions, I think thats why Whitedog´s LED does work, and some others don`t...
Engineer
701
The problem with the HD LED on the ATA66 controller was fixed with board revision 1.01.P (I have this board and all works O.K.) and later :)
Version 1.02 added thermal probe under CPU.
I have heard of 1.03 but have never saw any information on it. The manual revision is 1.03, but I don't think the two go hand-in-hand...
Good Luck...
watkins
69
A7V revision 1.01 w/bios 1004a. HD led seems to work fine.Using the ata 66 controller w/maxtor diamond max plus 40 -20 GB drive.
Jonny
1,574
Guys, just got my IMB Deskstar GXP 45gb, I hooked her up in ata 100, and the hard drive light works perfect. :)
Iam happy.
