I had been running with 1004 and decided to flash 1005. The flash went fine, I reset the bios and then changed settings as I had under 1004. The computer posts but won't boot (can't find the boot disk which is attached to the Promise controller). I was using the Promise controller under 1004 without problem and get the same sort of behavior as if the drivers were not loaded in windows correctly. I know I can disconnect the cable from the Promise controller and move it to the ATA-66 slot, but why is it doing this? Also, when using the Promise controller the Bios detects a boot virus (did this under 1004 as well). I know there isn't anything there (Norton does not detect anything), so why is that happening - I simply disabled boot virus detection in Bios (and it ran fine under 1004).
Do I need to go through the routine of switching the cables, loading the Promise drivers, etc.?
Any suggestions or explanations?
