Okay guys,
I was just reading the KT133A chipset and how you can use fsb 133 on the cpu..and i want to know if it's possible to do it on the KT133.. the A7V does support 133Mhz (pci 33Mhz). Is the a Way to modify the av7 or the a7pro to work at 133. i already tried it with my duron 600 and athlon 900 ( reduced the multipier to 6.0/6.5/7.0/7.5) but had no success.
Is this the same problem as the KT133A has with the default speed of the CPU being initialized before the bios. but the A7V is a jumpered mobo and i don't see that being a problem.
So is the KT133 that badly designed? or is there another way..
