A7N8X's problems hiting FSB200
0JK0
I have read so many times that people with A7n8x with revison lower then 2.0 can't hit the FSB200.
Did any of you guys upgrade to the newest BIOS(which-according to asus- provides FSB200 support), and then try to o/c?
Can anyone check it and try it because i have a7n8x deluxe rev.1.04, and i am about to buy Barton 2500?
None earlier than the Revison 2.0's were designed to run a 200 Mhz bus... so they haven't been tested at that speed, and thus aren't guaranteed to work at that speed.
Yeah, my 1.04 revision board with latest bios only hits 184mhz stable. If you look at the 6-way nforce2 shootout done by anandtech their pre-revision 2.0 a7n8x deluxe hit 185, which was about the average for boards before the 400 ultra revision came out
