A7N8X (non-d) and MBM question
Jamsan
795
I can't seem to find the right temperatures for my cpu and system using MBM...I've tried each diode, and they are all off a couple of degrees according to the bios temperature...For those of you whom have an A7N8X non-deluxe (I wanna say revision 1.04), what diodes are you using in MBM? Or if anyone has a better reccomendation for readings, thats fine as well..
And I doubt the temperature of my CPU will drop ~4C in the matter of seconds it takes me to reboot, go into the bios, and check the settings.
