A7N8X-DX, Sonata, Front-Panel Connections Help
WobbleWobble
4,867
I have a A7N8X-DX and an Antec Sonata which has front panel connections for the sound. Except I can't figure out how to wire it. I also had this problem with a P4P800-DX...
Has anyone been able to successfully hook up the front panel sound connectors?
paperfist
6,539
286
www.the-teh.com
I have my front Sonata panel wired up to my Abit NF7-S board. What prob are you having and did you look at the readme at Antec's site? They have 2 of the wires misprinted in the manual.
WobbleWobble
4,867
Thanks!
I for some reason forgot that a case manufacturer would have a web site (good stuff Antec!). I checked out the audio connector descriptions on the web site and got it working!
WobbleWobble
4,867
Actually, I noticed something funny when hooking up my front audio connections. Hooked up from the rear, the left and right channels are correct. Hooked up to the front, the left and right are reversed.
Anyone have this problem?
