ok ill start with my hardware setup.
-Asus a7n8x deluxe motherboard link here
-Athlon XP 2500 'barton' chip (clocked at stock. 166*11)(1.8ghz)
-two Seagate 160GB 7200rpm EIDE Barracuda hdd's. link here
-two CORSAIR MEMORY XMS 512MB 32MX8 PC-3200C2 W/ Heat Spreader
-koolance liquid cooling tower. link here
-koolance CPU-200G heatsink link here
ok i started by making a fat32 partition with bootdisks from partition magic 7.0.
then i formatted it with format.com off a win98se bootdisk. it said something about formatting 20gb? but formatted all 160 *shrug*.
now, i installed windows 2000 pro (regular. no sp's). updated to sp4.. when i rebooted it said 'error ntldr is missing' so i figured i could fix it. so i rebooted with the win98se bootdisk and looked at the c: drive. c:\winnt and all my files were deleted. and replaced with random gibberish files and folders.. corrupted completely.
so, i formatted with the 98se bootdisk again. installed win2k again. downloaded sp4.. worked this time. so i hooked up a old harddrive of mine as a slave to transfer old files onto it, messed around on the net while i waited.. froze during the end, rebooted. 'missing operating system, hit any key to restart' so i booted with the 98se disk again.. went to c:.. 'dir' and 'invalid media type, unable to read drive' so i formatted... again..
after formatting this time, i was thinking.. maybe that harddrive is faulty. so i swapped the two 160s.. slave for master, master for slave. installed win2k pro. again. updated to sp4. again.. after a while.. goofin off talkin to people. downloading stuff, just *reboot* restarts itself. and once again all my files are missing. everything replaced with corrupted gibberish. even the partition labels get filled with random ascii characters. so now.. im stumped.
i realized one thing, the two drives on the ultra ata ide cable.. are wrong, slave is at the end (black) master is in the middle (white) and blue on the motherboard. but i doubt having the master and slave on the wrong spots on the cable could cause any harm.. could it? if so why not earlier?. and also...
could my problem be i formatted with such a old floppy? win98se?
or is it a messed up bios setting thats doing something to my drives?
PLEASE help, this is very very frustratiing. im about to put it all in the microwave and be done with it.
Thanks in advance
Derek
Thanks in advance
Derek
