a7n8x deluxe- not working help
obi1
24
to all you lovely knowledgable people out there can you help? someone who is not very knowledgeable. just installed a7n8x deluxe mobo, turn on and it bleeps, post message tells me that it has past post and is now booting from operating system but keeps going back to post and not booting up. i am using samsung 2100 one stick and another pc 2100, i don't know what the crap is. amd2000 xp, bios what come with the board are 1001c, first time putting a mobo in probably the last the way this is going on, can anyone also tell me the corrrect settings to use on the bio page, don't laugh we all have to start somewhere
chizow
9,537
Is it saying "CPU is Over SPD"? If thats the case it thinks you are trying to overclock. Set your FSB to 133mhz and sync your memory instead of setting it by SPD. Also, keep RAM timings at optimal. What is it showing as your multiplier and FSB settings? You may also want to get the most updated BIOS, as the one that ships with the board essentially locks your multiplier.
Chiz
obi1
24
multiply is showing 12.5 not quite sure how to do the fsb, fsb on the motherboard is set to pins 1 and 2 333/400 not quite sure where to change the fsb on the bio page thanks for the help anymore help would be very appreciated.
obi1
24
change the cpu external frequency to 133 and put memory frequency on 133 still not working still doing the same thing
chizow
9,537
set the jumper to pins 2 and 3 for 133FSB (266 dual-pumped) as that is the default for your RAM. Also, take out the generic PC2100 and see if it boots (leave the Samsung in). Then try adding it back and see if thats the problem.
Chiz
Literatii
21
First reset your CMOS... remove the battery, and use the clear CMOS jumper for about 5 seconds. Then put the jumper/battery back (see manual).
Second, the a7n8x has notorious problems with Samsung RAM. The fact that you mixed and matched isn't good either. Try one stick at a time before pairing them up. Also, download Memtest86 and check your RAM (single or pairs doesn't matter -- go through the first 7 tests).
Things to try:
-In the BIOS set your CAS to a step greater than normal. ie: if you're running CAS2 RAM select CAS2.5 in the BIOS. This normally solves most Samsung RAM problems.
-If that works, try locking your AGP frequency at 66... THEN try setting your memory timings at their rated CAS.
I'm currently running OCZ PC2700 on that board at 3-2-2-2... but it took some fiddling.
obi1
24
hi thanks for the help much appricated will try these things it's nice to know that people are willing to help thanks once again obi
mechBgon
Oct 31, 1999
30,699
Are you expecting your WindowsNT installation to simply work after replacing the whole motherboard? That's being darn optomistic. I'm not sure NT *can* run on nForce or nForce2 boards. Win2000 Pro will work great, however.
At any rate, it's time to bust out the three setup floppies and the WinNT CD and see if you can force NT to install on nForce. Good luck. And if you don't have a high-quality 300W+ PSU, preferably higher, get one. Sparkle Power FSP300 or FSP350 are a good value, or Antec TruePower 330.
mechBgon
Oct 31, 1999
30,699
Then you need to change your SystemRig specs, which say Windows_NT ;) And the chances of switching mobos without a reinstallation of Windows are below 50-50, from what I've seen. Throw your WinXP CD in there and reinstall over the top of your previous install, which should retain all your programs and settings if you don't reformat the hard drive. If it won't run the Setup from the CD then you know it's not just a software issue.
ChampionAtTufshop
2,667
Originally posted by: obi1
tried booting from from windows xp cd but still nothing happened
i didnt read teh rest of the thread (time pressed) but to boot off the cd you have to set the optical drive to be first in the boot sequence (look in the bios)
Literatii
21
If you're getting endless loop boots, #1 thing is what I suggested: clear your CMOS. If you don't do that first, you're shooting yourself in the foot.
obi1
24
boot sequence is floppy first so i take it i change it to harddrive and then try thanks for the help forgive me for my ignorance but surely i should'nt have to boot from the xp cd to get the mobo working
obi1
24
thanks everyone for your help i'm now giong to try out your suggestions and get the screwdrivers out with the big magnets on top ha ha !!!!!!
Literatii
21
Make sure you wear fuzzy socks, put the computer on the carpet, and pet your cat before you start :)
mechBgon
Oct 31, 1999
30,699
What motherboard were you using before this? If it wasn't an nForce2 board, then yes, expect to have to set up WinXP from CD again. Win98 might manage to make the transition from one type of motherboard chipset to another (I've managed it a couple times), but I think WinXP would be Not Amused at the sudden change of the whole platform.
obi1
24
problem solved changed the boot sequence installed xp cd hay presto thanks for all your input could'nt have done it without you
