Hi,
I just got:
A7N8X deluxe
Athlon XP 2500+ Barton
512 cheap DDR400 RAM
new case ~$69CAN with 300W power supply - I can't tell what kind as it's obstructed.
Dropped in
old WD 40gb drive
old nVidia Geforce MX440
old LG CDRW
I haven't done any overclocking.
I ran the Prime95 torture test for an hour with ASUS Probe 2 running. It kept telling me that my Voltage was out of range. The 12V kept going above 13.2.
This isn't cool is it? Especially since I'm getting a Radeon 9800np soon.
Questions:
1. Should I get a new powersupply? What do you guys recommend?
2. Am I in danger of killing my system if I keep running it?
3. The bios didn't recognize the chip at first. XP was reporting 1.1Ghz. I had to manually set it up in the bios. Is this a sign that I should be flashing my bios?
4. I set the DDR400 to run at 166 in the bios. Is this the optimal setting?
Thanks,
I just got:
A7N8X deluxe
Dropped in
old WD 40gb drive
old LG CDRW
Questions:
Thanks,
