Ok to Start off My System:
Windows 2000 SP4
A7N8X Bios 1010 (latest Nvidia chipset driver)
AMD XP2200
512 DDR 400 Ram
ATI Radeon 9600 driver:catalyst-8-082-041130a-019577c
Sound Blaster Audigy
60 Gig Maxtor 80 Gig Maxtor
LG DL DVD Burner
350 Watt power supply
I just picked up a A7N8X motherboard
Now my probem is that every time I try to run the Audigy web driver updates it gets to a certain point then resets, just like I had hit the reset button.
I first checked the ram with Memtest86+ from www.memtest.org, no problems showed up let it run for 6 hours.
I have tryed moving the Audigy up one slot, Ive tryed uninstalling and reinstalling the driver to no avail. This all worked great in my older motherboard with was a SIS chipset. The onboard AC97 sound is disabled.
The Audigy drivers seem to be the only thing that does this, does anyone have any idea what might be causing this problem?
Every time it reboots it also seems to leave this in the Event System Log: Save Dump: The computer has rebooted from a bugcheck. The bugcheck was: 0x0000001e (0xc0000005, 0xeb6a4fbb, 0x00000000, 0x0063006e). Microsoft Windows 2000 [v15.2195]. A dump was saved in: C:\WINNT\Minidump\Mini012605-05.dmp.
Oddly all the error messages are identical, Anyone have any insight into what might be causing this? or any speculations?
Could the mother board be at fault? if not what might be?
Any help would be apprecatied
Windows 2000 SP4
AMD XP2200
512 DDR 400 Ram
LG DL DVD Burner
