A7m266 problem
Ph33zy
Does anyone know why the mobo fan and cpu fan wont turn on when everything else conncected to the the power supply works? The light on the mobo works but i cant figure out why the fan on the board and cpu don't...
do you have a spare power supply to swap in and try?
take out the mobo and look very carefully at the pins inside the molex plastic connectors, both male and female (especially the green) that connect the main power strand bundle to the mobo. take a jewelers screwdriver and see if you can wiggle looseness in the male mobo pins inside its connector
yea both power supplies won't work...hmm maybe i got a bad mobo.. The thing is that it did work before
but it has enough power to run the geforce2, my hd's and cdrom...does anyone know what could be the cause of this?
