Just built a new AMD 1.2 GHz 266 FSB system using Asus A7M266 Mobo. I also bought two Crucial PC2100 256MB SIMMS. Problem is the system is very unstable, keeps on coming up with various .DLL file problems and the odd VXD Blue screen error when both SIMMS are fitted, and I start using various programmes ?? System seems to run a lot more stable when only one 256MB SIMM is fitted (tried both individually in first DIMM slot...No problems) ??? I tried various Voltage settings through VI01 jumper, 2.5, 2.7 & 2.8 Volts.....Didnt help, same problem. Does anyone know the cause, or have a solution to this Problem ???
PS. What is the optimum or most stable Voltage setting for the Clock generator, Jumper VI0 for the AMD 1.2GHz 266FSB Processor....3.30, 3.45 or 3.56 Volts ????
