a64 temp problems
MadOni0n
379
My a64 2800+, ti4200, vnf3-250, samsung 512 2700, antec 350w smartpower comp seems to be running really hot. My cpu fan/heatsink is a zalman cnps7000cu which was suppose to be a really good and cool solution. My cpu temps are normally around 60c ambient or 70c on load. I reseated everything, used as5 and the same temps say. Could my bios be reporting it wrong or could something be with my sensors? im leaning towards a bios problem with the vnf3-250. i did some research and i found incorrect temps to be a common problem. if this is the problem, which bios version would fix it? i tried a 4/30/2004 version and the newest v5.0 .
Some everest info:
Field Value
CPU Properties
CPU Type AMD Athlon 64 2800+
CPU Alias Newcastle S754
CPU Stepping DH-CG
CPUID CPU Name AMD Athlon(tm) 64 Processor 2800+
CPUID Revision 00000FC0h
CPU Speed
CPU Clock 1808.60 MHz
CPU Multiplier 9.0x
CPU FSB 200.96 MHz (original: 200 MHz)
Memory Bus 164.42 MHz
CPU Cache
L1 Code Cache 64 KB (Parity)
L1 Data Cache 64 KB (ECC)
L2 Cache 512 KB (On-Die, ECC, Full-Speed)
Motherboard Properties
Motherboard ID 03/21/2005-nForce3-VN61C120C-00
Motherboard Name Chaintech VNF3-250 (5 PCI, 1 AGP, 1 CMR, 3 DDR DIMM, Audio, LAN, IEEE-1394)
Chipset Properties
Motherboard Chipset nVIDIA nForce3 250, AMD Hammer
Memory Timings 2.5-3-3-7 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
SPD Memory Modules
DIMM1: Melco 512 MB PC2700 DDR SDRAM (2.5-3-3-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz)
BIOS Properties
System BIOS Date 03/21/05
Video BIOS Date 08/29/02
Award BIOS Type Phoenix - AwardBIOS v6.00PG
Award BIOS Message VNF3-250 03/21/2005
DMI BIOS Version 6.00 PG
Graphics Processor Properties
Video Adapter nVIDIA GeForce4 Ti 4200
GPU Code Name NV25 (AGP 4x 10DE / 0253, Rev A3)
GPU Clock 250 MHz
Memory Clock 223 MHz
Field Value
Sensor Properties
Sensor Type ITE IT8712F (ISA 290h)
Motherboard Name Chaintech VNF3-250 / ZNF3-250GB
Temperatures
Motherboard 39 °C (102 °F)
CPU 64 °C (147 °F)
IBM IC35L060AVV207-0 40 °C (104 °F)
Cooling Fans
CPU 2596 RPM
Voltage Values
CPU Core 1.54 V
+3.3 V 3.18 V
+5 V 5.00 V
+12 V 11.78 V
-12 V -12.71 V
VBAT Battery 2.74 V
Chipset 1.63 V
DIMM 2.58 V
AGP 1.50 V
MadOni0n
379
last try, if the bios is my problem - does anyone have a version that displays temps correctly?
