bluehorizon
My A64 is running at 61 celsius idle... I'm not sure what the problem is (I am running a MSI K7N2 Neo Plat, which I hear has some problems reading temps w/ current bios). I'm using a thermaltake Silent Boost heatsinke with a thermaltake smart fan II running at 4000 rpms. I used Arctic Silver 5 thermal paste and lapped the heatsink so much that I can see my reflection in it.
I have two thermaltake smart fan IIs for exhaust running at about 3500 rpms and two side fans, plus a 120mm intake fan infront of the case (thermaltake XaserIII skull case).
I'm not sure what's wrong! One thing worth mentioning; I can wiggle the heatsink VERY SLIGHTLY if I try. Though, it doesn't move around in the case, and it IS tight, but since it's so big it's pretty heavy, so I think that's normal.
Any suggestions/ideas/advice?
Thanks...
Thanks...
