Hello,
My system is:
AMD Athlon 64 2800+ (Newcastle) - Family 15 Model 12 Step 0 Revision DH7-CG
MSI K8N NEO Platinum motherboard with latest drivers and BIOS ver 1.5
SevenTeam ST-350BKV 350W PSU
512MB Corsair Value PC3200 RAM CL2.5, Timing is 2.5-3-3-8
GeCube Radeon 9800pro - 128MB
Runing WinXP Pro SP2
When I install my memory on Slot 1 or Slot 2 I get tons of errors in Test 5 of Memtest86+ ( or Memtest86). But in Slot 3 I get no erros.
It seems that cooling the chipset helps, when I cool it with a fan I get less erros. I have also noticed that applying 2.6 volts to the memory helps a little. More or less then 2.6 V only make things worst.
I have replaced my mobo, my memory and my processor but the problem persists.
Any sugestion??
Thanks
My system is:
Any sugestion??
Thanks
