imported_michaelpatrick33
- Jun 19, 2004
- 2,364
- 0
- 0
One potential advantage of the AMD 64's is the 64bit boost from the extra wider registers that will, whenever Winoze 64 comes out, more than offset any speed advantage of DD2. From what I have seen also the DDR2 is not advantageous now but may be at DDR 667 and probably at DD2 800 but until latencies drop it is better for AMD cpus to stay on DDR1. I wonder if JDEC would support a 233 or 250 DDR1 spec now with DD2 out. I doubt it. A 250 x 4 HTT at stock for the AMD's would be quite nice.
Also, remember that as the CPU's get faster the memory controller gets faster. The 6.4 PC 3200, theortically, will be nearly 100% around the 4400+ model or so I would imagine and if they raise it to 250 (no real reason with no real bandwidth advantage and higher latencies), than the memory would be probably around 7700 for dual channel. How much advantage, I don't know? Is DDR2 going to hurt AMD. Only in the marketing BS department. A very lucrative market though.
