MrK6
Hi, first post, long time reader :thumbsup:
Last month I built the system in my sig, it flies. Now that the summer heat has died down, I'm going to try some more extreme overclocking. When I first built it I boosted it to 266x8 (2.13GHz) so that my memory, which I'm told is the bottleneck of Athlon64 systems, would run at 213MHz and 2.5-3-3-8 timings. I've seen people get Athlong 64's to 2.5GHz and higher, I just will be happy at 2.4 (266x9). Couple of rules I'm following, dunno if I've been misled :frown:. I read somwhere that if you put your HTT bus at more than its rated speed, it'll go unstable. So, if you raise the HTT, you have to lower it's multiplier to keep it in specs, in this case, specs are for 800, so 266x3 is 798. What timings are other people using? I tired CAS2 RAM before and my A64 didn't like CAS 2 at higher than stock speeds. 2.5 seems to do the trick for now. Temps are good, I'm using a K8 silentboost all copper heatsink lapped to 1200 grit with a thermaltake 90mm CAT, 50CFM, fan on top of it. Idle is at case temp (29C atm) and load temps are 10 to 15C above that depending on the vcore. So, I guess I'm looking for some pointers or advice on what I'm doing wrong. I tried running it at 2.4 (266x9) with the RAM locked at 133 (171 actual) to make sure that's not the limiting factor. It gave me a rounding error after 9 minutes. I was using 1.65vcore, but it overvolts up to 1.72. Thanks for any help guys, it's much appreciated. Peace, Mr. K6
