Originally posted by: MadRat
Overclockers Forum Has a group that is also involved in the testing. So far the results have been nil. But the guys at Hardforums are working on microcode, in the BIOS, next to see if that is the key. RiStaR is also working on sending a low signal to the pin to see if its a hi/lo switch rather than off/on. Alot of the effort has to do with Japanese sites working with HT in Williamette and Northwood cores using a modified Linux kernel. If software could activate the HT function then they'll figure it out. It may be a Windows issue just as much as a BIOS issue. Then again, some interconnections may simply not be connected on the chips and al this is futile. Aww, the challenge of proving the truth...
