A2DP method for PS3 to get game audio and chat?
lokiju
18,526
I've been using my Jawbone bluetooth headset to get the in game chat going for BlOps and it's an added level of communication with my team that I like but was really wanting a way to get A2DP bluetooth working so I can do both in game chat and game audio/music through one A2DP headset. I understand that the PS3 doesn't support A2DP and doesn't have the chipset, which makes it impossible to work with a built-in option. What I was wondering is if there would be a way to either output my receiver to a A2DP receiver for game audio but also some how also get in game chat.
The only thing I can even think of that'd make this possible would be a A2DP stereo headset that can do two different simultaneous connections/audio streams at the same time and then combine them into the one headset so one can receive the game audio/music and the other can send and receive the chat audio and mic.
Mar 11, 2004
23,444
5,852
You might try finding out more about this:
http://www.engadget.com/2011/01/07/creative-sound-blaster-tactic-3d-omega-headphones-have-a-long-na/
I'd personally recommend a solid headphone with a decent extension cable to your receiver and then just have a bluetooth mic for your input. The only way to do full bluetooth would be to have the mic connected to the PS3 and then a wireless headphone that comes off of your receiver (as the audio input), but that's a fairly pointless step, and you'd get better quality and better price just getting a headphone and extension cable.
lokiju
18,526
I ended up buying the Turtle Beach wired ones made specifically for the PS3 so I can have proper chat and game audio controls.
So far they're great. I'll probably also buy the 5.1/7.1 add on down the road so I can better tell direction.
