A way to copy protected text?
SpiderX
Some websites make it so that you can't highlight and copy certain parts of text. Is there a way to get around this? It's not that I have nefarious plans for it, I just don't want to have to spend the time to type it out.
Haven't tried this myself.... but maybe disable javascipts?
I usually highlight, then ctrl-v, or edit--copy. This is assuming that you can highlight at the very least....
Or you can view the source and cut and paste from there I guess...
1. print screen
2. open ms paint
3. paste image, save
4. open OCR software, capture text.
5. Nextel, done.
